We have a list of applications and specific team names existing in a SQL data base that we would like to appear within a drop down list in an issue collector. Is there some method that I can accomplish this task?
The third party app Elements Connect allows you to pull information from external data sources and display them inside Jira. SQL databases and many others are supported.
You can take a look at this documentation page if you'd like to get your heads around how it works: https://doc.elements-apps.com/elements-connect-cloud/global-level-administration/connected-item-configuration/query-and-template-configuration/database-items
If you'd like a demo, feel free to book one here.
Disclaimer: I am the Product Manager of the app
Best regards,
