Hi everyone,
I'm exploring the possibility of integrating Proforma for Jira with Google Cloud Platform (GCP). I want to know if there's a way to set up this integration, and if so, what steps or tools would be required to achieve it. Has anyone here successfully connected these two platforms, or does anyone have insights on how to approach this?
Thanks in advance for your help!
Hi Nahom,
I would recommend using a tool to configure this integration such as ScriptRunner Connect which will allow you to pull and sync data between both systems.
With ScriptRunner Connect you can get started for free here and start playing around to see how the tool could meet your requirements.
If you would like a demo to understand how this tool works better then you can request one here.
I hope this information helps.
Kristian
