  • Community
  • Products
  • Jira
  • Questions
  • Is it possible to a copy custom field value to for example the summary field from the trigger issue to an issue created by Automation?
Christian Axén
Nick Menere
February 26, 2017
Hi Christian,
Using Automation for JIRA, copying a field into the summary of an issue is actually not too hard with the use of smart-values.
In the summary you can reference the original issue and extract the value. Use a value like:
Your summary plus {{triggerIssue.fields.Custom Field Name}}
Simply replace Custom Field Name with the name of the field you want to copy.
This can be used in the summary of a sub-task using the "Create Sub-task action" or in the summary of an issue using the "Create Issue" action.
