Is it possible to add Cumulative Flow Diagram or other diagrams one can find under Reporting to a dashboard as a gadget?
Thank you.
I'm looking for a Cumulative Flow gadget also. If using a Kanban board that is a must for a dashboard.
This is a bit disappointing, it will be a real nice to be able to add CFD and Control Chart as a Gadget in Dashboard.
JIRA feels incomplete with reports that you cannot embed into dashboards. My efforts to get my organization to visualize their work on a Kanban board feel somewhat wasted if I cannot also show how we're performing via CFD and Control Chart gadgets embedded in a dashboard.
It appears there is a feature request for this exact feature. Please up-vote to make your voice heard!
There should be a way to add any Report to a Dashboard. This seems basic. Jira, please add this option!!
Also looking for a Cumulative Flow Diagram as a widget (or at least something that I can save the configuration). Anybody know of a ticket for this that we can vote on?
Looking for this too!
Try our Great Gadgets app. In the many gadgets offered, there is also a Cumulative Flow Diagram gadget. It is fully configurable, being based on a filter or board.
This is how it looks like:
For further questions, please don't hesitate to contact us at support@stonikbyte.com.
Danut
I see this gadget in my client's Jira instance, but may I know how to get this to my other Jira instance please?
I just saw this under the marketplace apps and raised a request.
Do you have Jira Cloud or Data Center?
Basically, you have to install the app on the other Jira instance.
Go to Jira settings > Apps > Manage Apps and check if Great Gadgets app appears on the installed apps list. If not, click Find new app, search for "Great Gadgets" and install it by clicking Install or Try button.
If you need more help on this, please contact support@stonikbyte.com.
Danut.
It is Jira Cloud. Maybe I don't have access to the manage apps, but I am waiting for the admin to approve my request to install this app. Thank you for your response.
My admin got it installed and I got the notification. But when I search for the app in Jira dashboard, it is not getting populated. I searched with Great and Stonik. Anything missing here for me please?
Let's continue the discussion via email instead of bothering others in this public thread. Please send an email to support@stonikbyte.com and someone will contact you shortly.
Danut.
yes, pls add this feature ASAP
+1, please provide this feature
I am also looking forward to be able to add the CFD to a Dashboard via gadget. It's sad to not have this feature enabled yet -- 2020 Jira team!
Dont understand why this feature was removed.
Used it extensively on dashboards together with version burndown - which is also gone.
Please bring it back!!!
+1 - Please provide
Another example of Jira cloud stripping out needed functionality. Ugh.
Also really want this.
Is there no way to use this gadget with kanban projects?
Would like this too
Also want this!
Hi Katja!
I am looking for the same answer.
It seems that it was present in the past only with Classic Boards (see the related article).
I cannot find it anymore in recent versions of JIRA, where it is available only in the Reports section of the Board.
Did you have any luck in finding a Gadget for recent JIRAs (> 7.1)?
Simone
