Is it possible to add a second project to a custom ‘Created vs Resolved’ report?
When you run the report you can choose to take issues from a project or a filter. You should create a filter, which selects issues from two projects, and run the report with the filter.
Wouldn't that combine them and display together ?
Yes, it would combine them. Ah, I see . you want to see them on separate graphs. I guess, it is not possible.
Try creating a filter that combines two projects and then use the created vs resolved gadget maybe :-)
Guess this will also combine and read them as one project
