Is it possible to add a specific color for PIE chart or Chart
Vimal K October 15, 2019
Is it possible to add a specific color for PIE chart or Chart.
For Exmaple :
PASS- Green
Blocked - Amber
Failed - RED
Tom Harris - Old Street
October 15, 2019
Hi @Vimal K ,
As Jack said, this feature isn't available out-of-the-box with Jira, so my team built an app to allow you to do just that! You can set the colors, re-order the segment as well as add multiple values to the same segments :)
The interactive demo playground shows you how it works without even installing the app: https://link.oldstreetsolutions.com/custom-charts-playground
We're adding new features all the time to this app, so any feedback on how to improve it would be appreciated.
There's also a companion Confluence app that has identical features so you can add high quality custom pie charts to your Confluence pages.
Jack Brickey
unfortunately not OOTB. There are however addons that allow you to do this. While I have never used any I did search the Marketplace once for this.
