  • Community
  • Q&A
  • Jira
  • Questions
  • Is it possible to auto-populate Elements Connect Configuration fields (Nfeeds) from parent issue
Sruthi Biju April 4, 2022
Is it possible to auto-populate Elements Connect Configuration fields (Nfeeds) from parent issue to child issue using groovy scripting (Behaviours/Listeners - ScriptRunner plugin)
Case 1 - From Epic to Feature
Case 2 - From Feature to User Story (Parent - subtask relation)
The user must see the auto-populated values at the Create screen itself
Simon Laffont
April 4, 2022
Hello @Sruthi Biju
I am part of the Elements Connect Support team.
When using a Listener, what you are asking for is possible using the Elements Connect API, based on the following examples: ScriptRunner - Use Elements Connect API in a script
This can be done by configuring the following Listener:
def issue = event.issue;
def pluginAccessor = ComponentAccessor.getPluginAccessor();
def plugin = pluginAccessor.getPlugin("com.valiantys.jira.plugins.SQLFeed");
def serviceClass = plugin.getClassLoader().loadClass("com.valiantys.nfeed.api.IFieldValueService");
def fieldValueService = ComponentAccessor.getOSGiComponentInstanceOfType(serviceClass);
def parentFieldId = "customfield_10403";
def childFieldId = "customfield_10404";
def parentFieldKey = fieldValueService.getFieldValues(issue.key, parentFieldId);
if(parentFieldKey){
    return fieldValueService.computeFieldsValue(issue.key, [childFieldId]);
else{
    return -1;
(i) Please replace customfield_10403 and customfield_10404 according to your own configuration.
Behaviours work differently and it's not possible to use our Elements Connect API in such a script.
Furthermore, it wasn't possible to populate a Connect field in any way until version 6.11, in which the following Change Request has been released: CO-3116 - It shall be possible to set the value of an Elements Connect field with Behaviours (ScriptRunner)
I advise you to read the following documentation on this subject: Can Elements Connect fields be manipulated from a ScriptRunner Behaviours script?
Please let me know if further help is needed.
Simon.
Hi @Simon Laffont ,
In both parent and child issues we have the same Nfeed field. We need to autopopulate the value we have selected in parent issue to the same Nfeed field we have maintained for child issue as well.
For e.g.:
Nfeed field : customfield_10403
In Parent captured some value for Nfeed field : customfield_10403 as "abc"
In child we need the value "abc" for same Nfeed field : customfield_10403
Sruthi Biju
Simon Laffont
April 5, 2022
Hi @Sruthi Biju
Alright, so here is the Listener that you could set up:
import com.atlassian.jira.config.SubTaskManager
SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager();
def connectFieldId = "customfield_10403";
def parentFieldValue = fieldValueService.getFieldValues(issue.key, connectFieldId);
Collection subTasks = issue.getSubTaskObjects()
if (subTaskManager.subTasksEnabled && !subTasks.empty) {
    subTasks.each {
        log.warn(issue.key+' has a subtask:' + it.getKey())
        fieldValueService.setFieldValue(it.getKey(), connectFieldId, parentFieldValue);
        log.warn('Connect field has been updated in '+ it.getKey())
This way, the Connect field will be updated in all subtasks of an issue.
I configured this Listener to be triggered on the Issue Updated event.
Please let me know if it works on your end.
Simon.
Sruthi Biju April 5, 2022
Hi @Simon Laffont ,
Tried to add the Custom listener in Jira (Data centre), but getting the static type checking errors. I anyway tried adding Issue Created and Issue Updated events, but the script didn't work as expected.
Sruthi Biju
Simon Laffont
April 5, 2022
@Sruthi Biju
The error messages on line 6 and 18 are probably because you didn't select any events:
If no event is selected, then the event.issue variable cannot be evaluated.
And the error messages displayed on lines 16 and 22 should be ignored. They are due to the Elements Connect classes (lines 9 and 10) that are not correctly interpreted by the Scriptrunner compiler. These are false positives and don't prevent the script from running properly.
This is explained in the following documentation: "Cannot find matching method" error message
Simon.
Hi @Simon Laffont
I have already added the events and still the listener doesn't work while creating the subtask issue and at the create screen of the subtask.
Sruthi Biju
Simon Laffont
April 6, 2022
Hi @Sruthi Biju
I don't understand why an error message is displayed for the event.issue. It should work, as mentioned in the Scriptrunner documentation:
You should contact the Adaptavist support team about this issue.
Apart from that, the Issue Updated event is only triggered when an issue is edited. For this listener to be triggered when an issue is created, you need to add the Issue Created event.
Furthermore, a Listener cannot be triggered when the Create screen is opened because a Listener is event-based and can only be trigerred once the issue has been created, not before.
To execute a script when a screen is opened, you need to use a Behavior script.
Simon.
