Is it possible to automatically start logging work after the user start working on an issue?
Hugo Eduardo Loureiro Amadeu
Hi everyone!
I would like to know if is it possible to automatically start logging work after the user start working on an issue? And, of course, after the user stopped working on this issue, the logwork should ends automatically as well.
Ramiro P
May 8, 2013
Hi Hugo, the Tempo Plugin (not free plugin) has a "Tracker" option for this:
https://tempoplugin.jira.com/wiki/display/TEMPO/Real-Time+Time+Tracking
Thank you Ramiro! But do you know if there is a way to do it without using plugins?
Ramiro P
May 8, 2013
No, no without some developing. Jira doesn't have a functionality like this.
Moumita Mallik
January 24, 2019
This is very helpful for me to auto work log in jira
https://app.jiraautolog.com/login
George Mihailoff
December 30, 2018
Old question, new answer -- automatically capture spent time based on workflow data.
You won't need to mimic such workflow with different tools. This add-on analyzes data, calculates time spent numbers and provides reporting capabilities.
mquade January 16, 2019
Hi, is it possible to install this plugin on a self hosted server or is it only available on cloud server? We are running an self hosted one... :)
Like # people like this
George Mihailoff
January 16, 2019
Pedro Fresco January 18, 2019
Hi Matthias,
     You can try Automated Log Work there is a server and cloud version also.
Paul Wagner - at - AC May 9, 2013
I had the same problem and didn't find a solution without buying the Tempo plugin - which was not option for me. I did create a "sort-of" solution using the Groovy plugin, a custom groovy script which adds 1 minute to a ticket, and finally modifying my workflows to fire the script every time a transtion going into an "in progress" state occurs.
This is not as ellegant as automatically getting the time worked on an issue; but at least allows for some data to start getting collected. My team can go back into their worklog and correct times without having to remeber what tickets they worked on. I'm sure with a little mroe hacking the Groovy script could do the calculation when leaving a Jira issue.
Also look up the Timesheet plug-in; it is a fraction of the cost of Tempo. It still will not do what you want, however with the script I mentioned above, it makes correctign time a lot easier.
If you use this technique for "automatically" logging time, make sure you put the Groovy script running Post-Action AFTER the Re-index action; otherwise the tickets are not re-indexed properly.
Groovy Code:
import com.atlassian.jira.bc.issue.worklog.*
import com.atlassian.jira.issue.worklog.*
import com.atlassian.jira.ComponentManager
import org.apache.log4j.Category
import com.atlassian.jira.bc.*
import com.atlassian.crowd.embedded.api.*
import com.opensymphony.workflow.*
import com.atlassian.jira.bc.issue.worklog.WorklogInputParametersImpl.Builder
import com.atlassian.jira.user.util.*
import com.atlassian.jira.issue.*
String currentUser = ((WorkflowContext) transientVars.get("context")).getCaller();
User currentUserObj = ((UserUtil)ComponentManager.getComponentInstanceOfType(UserUtil.class)).getUser(currentUser);
Issue issue = issue
JiraServiceContext jiraServiceContext = new JiraServiceContextImpl(currentUserObj);
WorklogService worklogService = (WorklogService) ComponentManager.getComponentInstanceOfType(WorklogService.class);
WorklogInputParametersImpl.Builder builder = WorklogInputParametersImpl.builder().issue(issue).timeSpent("1m").startDate(new Date()).comment("Auto Added 1 minute").groupLevel(null).roleLevelId(null);
WorklogResult worklogresult = worklogService.validateCreate(jiraServiceContext, builder.build());
Worklog worklog = worklogService.createAndRetainRemainingEstimate(jiraServiceContext, worklogresult, true);
Hi Paul!
Thanks for the code.
I'll try to use it on my solution.
Regards
Automated Log Work for Jira is a good choice.
Time is tracked in two modes:
  • automatic (based on workflow) or
  • manual (start/stop/pause timer buttons)
Reports with data export to XLS file for more sophisticated work data manipulation.
Available also server version
Jack Hunter _HeroCoders_
Clockwork Automated Timesheets app does exactly that.
It integrates with Jira's workflow and logs the precise time worked, depending on how much time an issue was in an active status ("In Progress" category).
The timers can be also started or stopped manually by using Start/Stop buttons.
The app also provides reports and it is free at the moment.
Jack
Fidel Castro
September 18, 2014
Timothy
May 8, 2013
Without plugins. No
