Apologies in advance if this has been addressed... I've searched and couldn't find a suitable answer. Is it possible to pull issues from Jira Work Management into a sprint created in Jira Software? For instance, if business users are using Jira Work Management for their project backlog but have a work request towards a group in I.T. working in Sprints, is it possible to collaborate in the Work Management project but pull those I.T. specific tasks into a sprint created in Jira Software? Or would we need to work in both tools for visibility? (Assuming the Project was already created and underway within Jira Work Management from initiation).
Good afternoon @Jeremy Nydegger
To achieve the collaboration you're looking for:
Project Structure and Permissions: Ensure that both your Jira Software project and your Jira Work Management project are set up properly. Make sure that permissions allow the necessary teams to access and collaborate across projects.
Linking Issues Between Projects:
Utilizing Boards and Sprints:
Workflow and Visibility:
If my response solves your question, please select it as the selected answer.
Thank you @Collista Lewingdon ; The specific note about Sprint Planning was specifically what I wanted to confirm. Appreciate the quick response!
