Is it possible to change field position in issue layout from left to right ?
rashami.abhyankar December 1, 2019
Is it possible to change field position from left to right ?
Jack Brickey
I don’t understand your question. Are you asking if you can change how where certain fields are displayed in the issue layout view? If so it isn’t possible. The issue layout has designated areas for fields based upon the field type or function.
Jack Brickey
You cannot do that.
Hi @Jack Brickey
kindly refer to screenshot.
