I need an automation rule while creating an issue, the responsible field should be filled with the project lead. I mean the lead field while creating a new project.
Is it possible?
An option (or addition of some kind) could be to work with components. They bring an built-in option with them to assign Project Lead.
From what you described you are not goint with components right now but a custom field - if this can be changed it would be possibly easy. If not some combinations of several methods could lead to a success.
Likely. I’m unsure if Project Lead can new accessed in Automation. Have you attempted as yet?
trigger - issue created
condition - whatever your needs are
action edit issue and copy project leader into custom field
:-( I had not ever attempted to use PL so was unsure. I may play with this bit to see if I have a better idea but in the meantime here are two ideas (not necessarily great but...)
Hi Jack,
i did the same steps as you described. My trigger - issue created then: edit issue fields - Responsible. But i cannot find lead. I only can copy from issues :/
