Is it possible to connect/integrate Jira with SharePoint 2010 out of the box or with an other tool?
An Example:
1. You enter a bug into Jira.
2. The bug will be synchronized with a SharePoint 2010 Server List
3. If you change a bug, SharePoint will be synchronized back to Jira.
Thanks a lot.
Not out of the box, although Jira exposes a lot via it's REST interfaces that you can hook into.
I'm not sure it'll match what you need, but http://wiki.customware.net/repository/display/CustomWare/Connector+for+SharePoint+and+JIRA is the only thing I know of that tries to get the two to talk to each other.
Do you have any idea if we have an integration option between JIRA CLOUD and SharePoint?
Swathi
Even less, most of the Apps for connecting them are server only. Search the marketplace for "sharepoint", and select "cloud" and "jira" in the criteria to see how out-of-date my memory is on that.
For what it's worth, there are a lot of options on the Sharepoint side if you have access to the sister-tool Microsoft Flow.
