Is it possible to connect two different JIRA instances to one SFDC instance?
Terry Wade
April 26, 2020
We currently have two Dev Teams that are working in different JIRAs.  Can we connect two different JIRAs to one Salesforce instance?
Bibek Behera
Hi @Terry Wade ,
I would suggest you explore the salseforce connector plugins available on the marketplace. I am sure one of them most be offering the same feature.
-Bibek
Terry Wade
April 28, 2020
Thank you, I think I found out what I need to do.   I appreciate it.
Bibek Behera
You are welcome @Terry Wade  !
Please feel free to accept the suggestion :)
-Thanks
Srikanth M February 18, 2021
Hi Terry
Did you find out the plugin? Thanks.
Joy Okorodudu
June 15, 2020
Hi @Terry Wade
Am currently faced with same issue of integrating Two Jira instance with one Salesforce Org , please advise how this was resolved on your end .
Many Thanks
Shubham Gupta
Hi @Terry Wade
You can try Sinergify- A Salesforce Jira Connector.
Sinergify is a connector for Salesforce and Jira integration. It allows the integration of all standard and custom Salesforce objects with Jira products.
I hope it helps.
