Is it possible to display a header above the Sub-Task column view when displaying a parent issues view screen? The header should simply list the column name.
br
Peter
Put this in announcement banner
<script type='text/javascript'>
AJS.$(document).ready(function() {
$('#issuetable').prepend('<thead><tr><td></td><td>Summary</td><td>Type</td><td>Status</td><td>Assignee</td><td>Progress</td><td>Order</td><td>Actions</td></tr></thead>');
</script>
Hi - Here's an updated script. I had to add AJS. in front of $('#issuetable').
AJS.$('#issuetable').prepend('<thead><tr><td></td><td>Summary</td><td>Type</td><td>Status</td><td>Assignee</td><td>Progress</td><td>Order</td><td>Actions</td></tr></thead>');
</script>
I believe that this is what you are looking for?
Thank you for the answer, and it was indeed what I asked for. However I should of course had mentioned that we are using JIRA 4.4.5 (soon upgrading to 5.2.x), and the solution you found is only applicaple pre 4.4.
Kind regards
Peter
