I believe is possible to see more than only assignee, reporter under the people section but how can I edit it?
Can this be configure for one project only or it will affect the whole system?
Thanks! Nice day :)
Hiiii paula
Every project can has its own screen in create and edit and view mode.so u can create ur own screen with ur favorite fields that u want to show.if u want do this. U must have administration permission and then create ur favorite screen and field configuration.
Hi Paula,
Any field of users or group type that you add to the view screen will be displayed on the people section.
For this you need project/jira admin permission.
Regarding the second question, the changes will affect the issues that are using the screen scheme you're changing. So if the screen scheme is shared it might affect more than expected. But in general, if the field is empty it doesn't get displayed, so you might not feel the changes.
Tanya
how can I do so the fields appears even if this fields have no value? Like with the asignee, that appears even when it has no default.
I'm also curious about that, which is showing empty user pickup fields
