Is it possible to have a linked issues in different projects update each other?
Colin Reed August 31, 2016
I want issues linked in different projects update eachother. Is that possible?
Nic Brough -Adaptavist-
August 31, 2016
You'll need to find/write code that can pick up changes and push them to issues you select at the other end of the links.
Does that include transitioning linked issues? I apologize if to this question answer is obvious.
August 31, 2016
Yes, it'll need code.
There's a few add-ons in the marketplace that can do this sort of think, well worth a look.
