Is it possible to have a transition's post function to perform a "Move" operation?
Gabriel June 16, 2014
The context:
Project A is essentially an escalations team, the final tier of direct customer support.
Project B is the entry point for engineering issues.
My use case:
I have two disperate projects that usually do not interact with each other at all. There are times however, where issues from Project A need to be moved into project B. I want to achieve this with a workflow transition so other custom post functions are programatically run at the same time this "Move" occurs.
So, is this possibel? If so, how?
Thanks!
Gabe
Gabriel June 24, 2014
Thanks, I ended up using some Groovy via a great plugin, ScriptRunner.
Danilo Conrad
June 17, 2014
Hi Gabriel,
This is not supported in JIRA by default (see feature request JRA-9564).
It seems there is a third party plugin which may provide this functionality (Minyaa):
http://www.minyaa.com/documentation/3.3/Features/ModuleWorkflows/WorkflowFunctions/MoveIssueFunction.html
I hope this information helps.
Danilo
