Is it possible to have two edit issue screens in JIRA?
Tayyab Bashir
April 25, 2016
I want Closed issues to be editable but I don't want the edit screen appearing on Closed issue to provide all the fields that available in normal transitions?
I know how to make closed issues editable.
So for e.g, the issue is on "Review" stage, and if I edit the issue, it gives: Comment, assignee, XYZ field.
What I want is that when the issue is in "closed" stage, and I click edit issue button, it only gives option of Comment field.
Regards.
Tayyab
Nic Brough -Adaptavist-
April 25, 2016
No, you can't do that without
  • coding
  • Behaviours in the Script Runner add-on could check the status and hide all but the comment field on the single edit screen
  • Move the "closed" edit into the workflow
Michael Partyka
April 25, 2016
it is possible but only for different issue types.
For one issue type it is not possible.
