×Hi Sibel - Roadmaps are only available for Next-gen projects, not classic projects.
You can read more here: https://community.atlassian.com/t5/Next-gen-articles/Classic-and-next-gen-project-templates-in-Jira-Software-Cloud/ba-p/862404
Hi John, thank you!
Can I simply create a next-gen project over the system dashboard?
Or do I need specific tools?
Sibel
There is a general problem. I can't see next-gen as a choice. Please find an attached screenshot.
is that normal?
I've found out, that we use Jira Server, not Jira Cloud. Therefore I cant find under system a place to enable this functionality.
But thanks for your help John.
Kind regards
Ah, I don't think Next-gen projects are available on Server.
