Is it possible to install Jira-Agile on system with no internet connectivity?
David Weibel
January 10, 2014
Is it possible to install Jira/Jira-Agile on a system with no internet connectivity? How painful is this? what are the dependencies?
Peter T
January 10, 2014
Yes you can. No worries with that I quite often install JIRA on local VMs which are not connected to internet. The only functionality that won't work is browsing and installing add-on from Atlassian Markplace directly. You have to dowload the install files and then upload them through the UI. Obtaining license key will have the same issues with the same workaround.
Scott Ortel August 7, 2014
So, do you need to configure JIRA differently in this case? I'm getting lots of errors all over the place where JIRA is trying to reach altassian.com.
Steven F Behnke
August 8, 2014
Hi Scott! You should ask a new question for yourself instead of tacking on here.
Since we're here: The plugin marketplace will reach out and attempt to talk with atlassian, and will be unable to do so. I can't imagine any other components that would have issues off the top of my head, where are you seeing issues or errors?
Scott Ortel August 14, 2014
Understood Steven. Thanks for the tip.
I have the atlassian marketplace disabled via the configuration. However, I am getting a script error when trying Agile->Getting Started. It appears to be trying to load a .js script from atlassian.com
