Is it possible to integrate Jira with WebSVN?
Tom Isaacson November 20, 2011
I can get Jira to see my Subversion repository but we're using WebSVN and all I can find about integrating this suggests it's not possible:
http://forums.atlassian.com/message.jspa?messageID=257277169
However, this is from 2008 - has there been any change since then?
Thanks.
Norman Abramovitz
November 20, 2011
It should be possible by modfiying the command strings where the repository is defined. You will need to look at the command line arguments for websvn and look at the Jira documentation about the substitution variables.
Something like this could work for you with modifications to mycompany and websvn version information.
# WebClient for SVN (2.0)
linkformat.changeset=http://svn.mycompany.net/websvn-2.2.1/revision.php?repname=source&location=/&rev=${rev}
linkformat.file.added=http://svn.mycompany.net/websvn-2.2.1/filedetails.php?repname=source&path=${path}&rev=${rev}
linkformat.file.modified=http://svn.mycompany.net/websvn-2.2.1/diff.php?repname=source&path=${path}&rev=${rev}&sc=0
linkformat.file.replaced=http://svn.mycompany.net/websvn-2.2.1/filedetails.php?repname=source&path=${path}&rev=${rev-1}&sc=0
linkformat.file.deleted=http://svn.mycompany.net/websvn-2.2.1/filedetails.php?repname=source&path=${path}&rev=${rev-1}&sc=0
linkformat.copyfrom=http://svn.mycompany.net/websvn-2.2.1/filedetails.php?repname=source&path=${path}&rev=${rev-1}&sc=0
Thanks, this works once modified (I also had to change the repository name from "source"). I had to add another link for View:
Oleg Burmistrov
If anyone by any chance come here here are the paths we've used with current versions of WebSVN:
Changeset Format: https:// <svnpath>/<websvncontext>/listing.php?repname=<you_svn_rep_name>&peg=${rev}
File Added Format: https:// <svnpath>/<websvncontext>/listing.php?repname=<you_svn_rep_name>&path=${path}&peg=${rev}&sc=0
File Modified Format: https:// <svnpath>/<websvncontext>/listing.php?repname=<you_svn_rep_name>&path=${path}&peg=${rev}&sc=0
File Replaced Format: https:// <svnpath>/<websvncontext>/listing.php?repname=<you_svn_rep_name>&path=${path}&peg=${rev-1}&sc=0
File Deleted Format: https:// <svnpath>/<websvncontext>/listing.php?repname=<you_svn_rep_name>&path=${path}&peg=${rev-1}&sc=0
JamieA
November 21, 2011
It is possible as above, however you should take the patch that allows you to use the repo name as a parameter to avoid hard-coding it as in Norman's example, think it's this one: https://studio.plugins.atlassian.com/browse/SVN-35
Not a big deal if you have one or two repos but if you have thousands like some svn users it's a must-have.
