Is it possible to move WBS ticket template between project ?
New December 12, 2017
Hi Support,
Is it possible that WBS plugins support import function?
I need to move WBS issue ticket to another project but found that WBS didn't have import function?
I have tried to use jira move function to move to another project but it only move its WBS ticket template issue,the issue link of the issue didn't move to other project,could you please give me some suggestions?
Thank You.
Pedro Santos
a template in WBS Gantt is a Jira issue, so you should be able to move it to another project.
Have you tried this?
Nic Brough -Adaptavist-
December 13, 2017
Could you explain what Warwick Business School has to do with this?
The rest of your question doesn't really make a lot of sense unless you can explain that and what your imports and templates mean.
New December 13, 2017
Hi Support,
I mean the WBS Gantt-Chart for Jira plugins not Warwick Business School.
It only has export WBS issue template function,but we want import WBS issue template function to import template between different project to use it.
Thank You!
