Is it possible to perform post function based on values of multiple fields?
Daisuke Niwa
Is it possible to configure workflow so you can perform post function based on values of multiple fields?
Let's say assignee is A and version is 1.0, the post function set value B to custom field C.
We appreciate your input.
Daisuke Niwa
Deleted user July 4, 2011
Short answer is I think yes. Slightly longer answer: When a post function fires, its in response to a transition. As the 'postfunction' is Java code, you have access to the issue, you are able to determine anything about that issue, eg assignee, version it is due for fixing in and are able to modify the issue on the way through also.
Daisuke Niwa
Hi Andy,
Thank you for your response. It looks as if we need to develop a plugin for this purpose.
Daisuke Niwa
