Is it possible to personalize an issue's report?
Aline Ribeiro June 4, 2018
I need to check the values in certain custom fields in a report and maybe even print the report.
Brant Schroeder
You can create a report on a Jira dashboard or in Confluence that pulls the information from a Jira filter.  The Jira filter will allow you to check the value in a custom field and display the report information you desire.  You should be able to print either report.  The confluence report will probably look nicer than the Jira dashboard.
Aline Ribeiro June 5, 2018
Ok! Thank you.
