Is it possible to query for a spcific issue and open (browse) it immediately?
chefkoch May 27, 2013
We are preparing a switch from Mantis to JIRA, but would like to keep all the existing links to the mantis instance within forums and other resources working.
Is there a way to automatically open/browse an issue immediately if the search result of a JQL has only one item?
FYI: we will store the old Mantis ID within a custom field so we are able to query exactly one unique issue.
chefkoch June 12, 2013
For now we will use the redirect to the search result only.
In future perhaps we'll use the search / lookup via the External issue id, parse the search result, which is given as xml and then redirect to the corrent JIRA issue directly. Should easy to set up for our web admin.
Nevertheless it would be nice if JIRA could have a search parameter to show the issue itself if there is only one result, instead of showing the search results.
AmandaA
May 27, 2013
In the issue navigator, after you query out the unique issue, you can simply use the shortcut to open/broswer that issue directly.
The shortcut key is: o or Enter
Note: This is only avaiable from JIRA's view issue and issue navigator screens only.
More shortcuts in JIRA, you can have a look at:
https://confluence.atlassian.com/display/JIRA/Using+Keyboard+Shortcuts
Timothy
May 27, 2013
If you use the detail view, you just need to click the returned result.
https://confluence.atlassian.com/display/JIRA/Using+the+Issue+Navigator#UsingtheIssueNavigator-DetailView
