Hi Team,
I need to restrict external users for some issue based on the value updated on "component" field.
eg:
Issue 1 - component (AA) - it should be visible to user.
Issue 1 - component(BB) - it should not be visible to user.
Is it possible....?
Pradeep KM
Choosing Components is one side of the Story,
You also need to define to whom the Issues should be visible for each Security Level.
For Example:
Say if we have Level 1 Security Level --> Only People in Level 1 should be able to select the Components
Security Level | Group/Role | Components |
Level 1 | Admins | Comp 1, Comp 2 |
Level 2 | Developers | Comp 3, Comp 4 |
With the above approach, you cannot restrict who can choose Security Levels, but not the Components.
So to achieve this, make a combination of Security Levels that maps to components and add the Automation rule as suggested by @Sandesh Shetty
Pramodh
You can use issue level security. For eg. security level A for component AA, security level B for component BB etc. And Add necessary users on security levels.
Please refer this doc. for information https://confluence.atlassian.com/adminjiraserver/configuring-issue-level-security-938847117.html
I am aware about issue security scheme but my requirement is different.
example :
1) If story issue having component field updated as "AA" it should be visible to external user.
2) if story issue having component field updated as some other value then issue should not be visible to external user.
Is it possible.........?
You can restrict issue visibility only using issue security levels.
You can use some automations i.e. when a component is selected automatically issue security level is selected to that story.
