Is it possible to review an Issue?
Chris Ryan
Hey all,
Does JIRA have the capability to create a review for an issue? Also, to give the issue a name, a due date, and to set reviewers.
Another spin on this is to give users the ability to Approve an Issue prior to implementation.
Thanks a million,
Chris
Tanner Wortham
January 8, 2014
our workflow looks like this:
To Do -> Doing -> Reviewing -> Done
we have a custom field called "Reviewer" and when a user moves an issue from Doing to Reviewing, it automatically reassigns it to this reviewer by way of a post function. (we also have some custom code that sets reviewer == assignee so it doesn't wig out by trying to assign an issue to no one.)
i've placed a screenshot of what this post function looks like along with the custom code we use.
import com.atlassian.jira.user.util.UserManager
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.event.type.EventDispatchOption
import org.apache.log4j.Category
log = Category.getInstance("com.custom.Reviewer")
log.setLevel(org.apache.log4j.Level.DEBUG)
log.debug("---- begin reviewer post-fuction -----")
def assignee = ComponentAccessor.getUserUtil().getUserByName(issue.getAssignee().getName())
def reviewerCustomField = ComponentManager.getInstance().getCustomFieldManager().getCustomFieldObjectByName("Reviewer")
def reviewer = issue.getCustomFieldValue(reviewerCustomField)
log.debug("assignee: $assignee || reviewer: $reviewer")
if (reviewer == null) {
	log.debug ("Empty reviewer.  Set to assignee.")
	MutableIssue myIssue = issue
	IssueManager issueManager = ComponentAccessor.getIssueManager()
	UserManager userManager = ComponentAccessor.getUserManager()
	myIssue.setCustomFieldValue(reviewerCustomField, assignee)
	issueManager.updateIssue(userManager.getUser("automation"), myIssue, EventDispatchOption.DO_NOT_DISPATCH, false)
log.debug("---- end reviewer post-fuction -----")
Chris Ryan
Hey Tanner,
We were hoping to avoid modifying the workflow, but this looks like the closest we'll get.
Thanks!
Chris
Tanner Wortham
January 27, 2014
you're smart to want to avoid modifying the workflow as much as possible. the more steps in the workflow, the more time your team needs to spend in the tool. but on rare occassion, a changed workflow is the best avenue of approach.
Chris Ryan
