×A user would like to bring every issue where their component starts with 'teste -*' for example.
If it was SQL qyery it would be like: where component like 'teste -%'
Thanks in advance.
if you are open to solutions from the Atlassian Marketplace, this would now be easy to do using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting - as well as the ability to filter issues via regular expressions.
With regular-expression-based filtering, you can apply pretty much any logic, including the one that you are after:
Once you've narrowed down your list of issues, you can work on your issues directly in JXL, trigger various operations in Jira, or export your issues with just one click.
Best,
Hannes
welcome to the communty
unfortunately this is not possible out of the box. You can only search by component name or id
