Is it possible to split the project into components for integration with the slack?
Daria Butinskaya
January 22, 2025
Is it possible to split the project into components for integration with the slack? To create a separate notification channel in slack for each component.
Karan Sachdev
March 31, 2025
Hey @Daria Butinskaya
You can add JQL in the notification settings in Jira (under project settings > Apps > Slack Integration). This should trigger the notifications only for the issues that qualify the specified JQL:
Thanks!
