Is there still any way you can create a Jira Custom field using Java ?
Hi @kaushik thakkar ,
You can create custom fields via API with any language you prefer to call out the API. Whether it's python, java, etc. Here's the API calls:
Now if you are looking to create a field with java code embedded, then that's a NO. You maybe able to add some code using marketplace add-ons that extend custom field capabilities.
Thank you Benjamin for your prompt response.
So basically we don't have the SDK functionality in cloud now where we can build our custom field if I understand that right from your 2nd statement. (Like how we had for server)
Also , do you have any reference to end to end guide of building API using java ? I understand the the link has only the src code.
Thank you once again.
Regards
Kaushik
Unlike on-premise versions, where you could extend products with new capabilities using the Atlassian SDK, the equivalent for cloud is the Forge platform. It’s entirely possible to create your own custom fields on cloud, but you’ll be working with JavaScript rather than Java.
Forge runs on Atlassian’s infrastructure and handles most of the heavy lifting for you.
Check out the Forge documentation for more details:
https://developer.atlassian.com/platform/forge/manifest-reference/modules/jira-custom-field-type/
If you’re new to Forge, I recommend exploring the Atlassian Learning path to get up to speed:
https://community.atlassian.com/learning/path/get-the-most-out-of-forge
Thankyou @Sarp Egemen . Yes using Forge will be the way ahead, thanks.
However I wanted to know if the API calling has been supported using Java, definitely you can do lot of things using that , so what exactly is supported using Java i.e. if in the below link suggested by Benjamin, most of the things I can do using Java API (along with python, forge and so on...),
How would the ecosystem look like in this case i.e. to be very specific ,
If you see the forge tab of any API , its understod that the index.js file should contain this code, where I do have other dependencies as well like manifest.yml , src folder etc.
Similarly , if I have to use the Java capability of API, how should my other components look like in the IDE view ?
REST APIs (and GraphQL, for that matter) are language agnostic. You can call them from any language that supports HTTPS, including Java.
If you decide to go the Forge route, I highly recommend checking out the learning path I mentioned earlier, along with the official documentation.
To quickly recap, as you asked: manifest.yml
is where you declare the components that will extend Jira (or any other Atlassian app), while index.js (
which can be named differently if specified properly) is the entry point for the front end.
When building a Forge app, keep in mind that the platform is opinionated: there’s no straightforward way to set up an ecosystem with a hosted Java backend and connect to it from the front end. That approach belonged to the previous platform (Connect, which is now sunset).
Now, with Forge, backend functions (called resolvers) run in a FaaS environment, fully managed by Atlassian and written in JavaScript (or TypeScript, of course).
@kaushik thakkar To add on to @Sarp Egemen's response, another option is to leverage Forge’s Remote module, which allows you to run your business logic on your existing infrastructure. This way, you don’t need to migrate or duplicate your backend services into Forge — you can simply connect them.
You can find more details here:
