Is possible to configurate cloud based Jira to track issues from Polyspace access?
Denis Riabov
February 23, 2022
I am trying to configure Jira as the issue tracker for Polyspace access to enable the creation of tickets from the Polyspace Access interface.
The Polyspace Access supports this type of integration with the Jira Software but requires  OAuth as an authentication method with generating of RSA public/private key pair.
Is it possible to get this key for Jira Cloud?
kuldeep Singh
February 23, 2022
@Denis Riabov ,
Welcome to the Atlassian Community !
The option you're asking for it is available in the Jira cloud but you need admins access for the Jira cloud,
This option is available under "Find new app" or Manage app.
Thanks.
Denis Riabov
February 24, 2022
@kuldeep Singh Thank you for answer.
I found this option and trying to understand how to get OAuth1 consumer key and OAuth1 private key file (which are required for Polyspace) from available OAuth credentials.
Here is what Polyspace manual says about this type of integration
But I have no idea how to get "the private key file" from Jira cloud.
kuldeep Singh
February 24, 2022
