Is possible to divide tickets into two group ?
Deleted user January 15, 2019
Hi All,
I would like to separate two specific kind of tickets :
1) complete - issue is fixed
2) complete - issue is out of date.
I dont want to use labels etc. because I need to see them on reports.
Joe Pitt
The simplest way is to have two resolution values.
Jakub Hanak
January 15, 2019
Hello @[deleted],
If I understand correctly it is about closed tickets. Maybe try to use "Resolution" field to separete these two types.
And you can also run a report for this field.
Best regards,
Jakub
