Is the Power BI connector for Jira Cloud updated to the latest version automatically, or someone has
Srinivsarao Mutyam March 6, 2023
Is the Power BI connector for Jira Cloud updated to the latest version automatically, or someone has to do it?
Plan: Atlassian Cloud (Premium)
3 accepted
Satish Putnala July 19, 2023
Is there a Power BI connector for Jira Service Management->Jira Assets?
Liubov Topchyi
July 21, 2023
Hello Satish @Satish Putnala ,
Power BI Connector for Jira Cloud allows exporting Jira Assets data.
The following tables are available for export:
If you have any questions during your trial, please contact Support. They will help you with all the settings needed.
Luba
Satish Putnala July 21, 2023
Thanks Liubov!
I don't see the "Assets" when i'm trying create a data source with Power BI Connector for JIRA, below is the screenshot.
Liubov Topchyi
July 23, 2023
A Jira API token should be added under the Tokens tab to export certain tables from Jira.
Please follow this guide to set up Insight tables export: https://aserve.atlassian.net/wiki/spaces/PBCFJC/pages/2346352641/How+to+export+Jira+data+requiring+Jira+API+Token
Please let me know if this helps.
Luba
Satish Putnala July 24, 2023
Hi Luba,
Thanks for reply, but unfortunately it does not be helpful. As I already have Token generated and in use.
Q1: To be able to get Assets when i try to Create a Data Source rom Power BI connector, what kind of access privileges we need from JIRA side?
Q2: Our end goal is to get Assets tables by creating a data source NOT from JIRA API, so that we consume the assets tables in Power BI.
Q3: The below help links you are sending are not accessible, it says "doesn't have access to Confluence on aserve.atlassian.net."
Ex: Please follow this guide to set up Insight tables export:
Satish Putnala
Liubov Topchyi
August 4, 2023
Let me answer your questions.
Answer: you should have application access to the Jira Service Management Premium plan. From the screenshot you provided, I see that you have application access to Jira Service Management. If you have a Premium plan on your Jira, by adding a Jira API token under the Tokens tab you'll get additional tab Assets under the Data Source configuration page:
Answer: After adding Jira API Token under the Tokens tab, you'll be able to select the following tables and pull them into the Power BI Desktop
Answer: it looks like you are trying to access the Confluence page as an internal user. Since you are not an internal user, it responds to you with a forbidden error. Please try to view the documentation from an incognito window and let us know if this is the case.
Luba
Liubov Topchyi
March 6, 2023
Hello @Srinivsarao Mutyam ,
Usually, the app is automatically updated. Occasionally we release updates that require manual updates, but you'll see the informational message about a required manual update in the interface.
Please let me know if you have further questions.
Luba
Dave Mathijs
Hi @Srinivsarao Mutyam welcome to the Atlassian Community!
My initial thought is that this would all happen automatically in Cloud. However, upon checking on my own site, I noticed 1 installed app that had an update pending.
The best way to get confirmation is to get in touch directly with the marketplace partner.
Yeah, I did
