I want to be able to have the user see on the dashboard issues that are "Past Due", "Due This Week", and "Due in Two Weeks". Is there any way that this is possible with the gadgets already provided to me in JIRA Software? Would I have to look for a certain add-on to make this possible?
Ian Balas
Hi Ian,
You could us the 'due' field to create a filter that shows all the issues that are past due, due this week, and due in two weeks, and then add the filter gadget in the report. E.g.:
Due by the end of this week:
due < endOfWeek() and due > startofWeek()
Due by the end of next week:
due < endOfWeek("+1")
due < now()
Carlos
Meaning you have to have a Field on your task called " Due Date" or based on what Jira knows is due that week ?
I have the situation that i have a field called " customer inquiry received date" and i have only 2 days to answer, then i have another date field called " customer quote requestdate" and i have 10 days to answer.
how can I do it using this proposed solution?
you can use the gadget Issue Calendar which has the functionality to calculate the Due Date
Hi Ian,
Consider using filter result gadget and create unique filters and gadget for each.
e.g.
Hi @Ian Balas
If you have the Scriprunner plugin you can create scripted fields to represent derived data values
There is an add-on that I have created, which has some of the required functionality (overdue, due this week issues listed) - https://marketplace.atlassian.com/apps/1219429/status-progress-report-gadget-for-jira
