Is there a built-in JIRA custom field that allows appending?
Karen Clark October 17, 2012
I have a Salesforce to JIRA connector that writes values to specific JIRA fields that I have mapped.
I would like the connector to append a value to the JIRA custom field, rather than overwrite it.
Is there a built-in field type in JIRA that I can select which would accept the (text) input from this connector to allow each entry to be appended rather than overwriting the previous?
Thank you!
Karen
Timothy
May 6, 2013
I came across this add on that does text manipulation:
https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.keplercf
Karen Clark May 21, 2013
Thanks Timothy. I not quite connecting the dots though regarding how that field would allow appending from an API call via a connected app...
Daniel Fowler May 6, 2013
Bump. Somebody out there must have run into a similar issue.
Daniel Fowler April 8, 2013
Poke. I am running into a similar issue. For a Helpdesk application, need to be able to capture and append replies received via email (using JEMH) to a field that is not necessarily viewable by the issue reporter (depending on role) BUT want original basic commment functionality intact to allow interaction with the reporter.
