Is there a dynamic checkbox for issue views?
Jason Ried
This question is in reference to Atlassian Documentation: Adding a custom field
Is there a way to allow users to enter checkbox tasks onto an issue?
This would be as follows:
  • Create or edit and issue
  • While editing add a task in the checkbox area, perhaps "model the trees"
  • Then you can add another, and another, as many as you want
The goal would be almost like having sub tasks but without having sub tasks obscure the scrum view, they're instead simply data on the issue view.
I've had a look and can't find anything so hoping there's a clever way.
thanks,
Jason
Nicolas Bourdages
July 5, 2016
There are plugins for task lists. Some work only on Cloud, some only on Server. This one should work for you:
https://marketplace.atlassian.com/plugins/com.gebsun.plugins.jira.issuechecklist/cloud/overview
