Is there a place to set project description and maybe some notes about it that are not task dependant?
William McCarthy
August 5, 2015
Sateesh Chandra
August 5, 2015
Browse to Project Administration as project admin / JIRA admin . Click on Edit Project button. You can also use html in the description
Robert Dzido _Almarise_
August 5, 2015
Each project has its own description. It's visible in Summary Tab.
To edit this description go to project page (menu Projects -> select your project) and click cog icon in bottom left corner of the screen, then clik Edit project button (top right corner of the project administration screen).
