Is there a post function that will automatically assign a Reopened issue to the user who Resolved it?
Paul Shinoda
Is there a post function (or a way to create one) that will automatically assign a Reopened issue to the user who Resolved it?
Udo Brand
March 11, 2013
Hi Paul,
I can think of following setup.
In order to resolve an issue you need to go through a transition (not just by Edit). Then copy the assignee
into a new custom field (named Resolver) as a postfunction of this transition.
If this issue then goes through the Reopened transition copy the value of Resolver into Assignee.
That should work,
Udo
Kota Sreenivasa Shravana Kumar
Hi Paul
I have the same requirement in our setup.
How did you manage to implement this ? Can you please share ?
Thanks !
Thiago Ribeiro
March 11, 2013
Paul,
There is a plugin that will definetly help you to set this:
JIRA Misc Workflow Extensions
You can use the post functions on your workflow to assign it to the last user.
Have a look on their documentation to understand more about its features.
I hope it helps you!
