Hello I'm trying to see issues with a certain component with a custom field empty
I preform this filter "project = SUPP AND component in (MESSAGERIE) AND "Projet Jira" is EMPTY" but it doesn't show anything while there are many tickets in this case
Is there a way to have the good result? Or is my filter wrong?
Thank y'all for the concern
Hi @Ulrich Kone - Welcome to the Atlassian community !!
Request you to please check the JQL in different parts, like:
It would help you to understand which criteria is leading to NO result.
And could you share a screenshot of an issue which is justifying this criteria ? And share some information on "Projet Jira" field.
Thank you !!
Hello @Deepak Jain
Thanks for your answer. Il attached the screen needed.
The Custom Field is only set for the project SUPP and the component value too.
Hi @Ulrich Kone
Thanks for all these details, could you please let us know - "Project Jira" is what type of custom field ?
Thanks !
I doubt you are facing this Bug - https://jira.atlassian.com/browse/JRACLOUD-67435
Lot of users are facing this issue on Jira server also, could you please try workaround given in the ticket.
Thanks !!
Hi @Ulrich Kone , thanks for your question. Have you verified that there are issues that match this criteria? The green tick is indicating that the query is written correctly so I would check the issues first.
Hello @Valerie Knapp, thanks for you answer. There are several issues that meet this criterion mentioned in the jql.
I don't understand the result
