×Hello,
We are looking for a solution that would allow us to plan work on issues/projects for teams of workers (such as field support engineers). The requirements based on our use case are the following :
Do you have any idea of a solution that would cover our requirements?
Hi there @Clémentine Arce ,
you could to that with the Outlook calendar and meetings integration of Microsoft 365 for Jira (Outlook Email, Teams, Calendar) | Atlassian Marketplace (available for DC).
Here's a short overview of the features that might be relevant for you: Outlook Calendars for Jira - yasoon. Please note, I work for yasoon, the company developing Microsoft 365 for Jira, therefore I tend to recommend the app :)
Microsoft 365 for Jira integrates Microsoft Teams, Outlook email and To Do, as well. This might be useful for your planning and communication. If you want to discuss your use case with our team, feel free to book a demo.
Hope that helps, best,
Britta
Hello Britta,
Thanks for the app suggestion, it looks promising. We will explore the app, and book a demo if our teams express further interest!
Best regards,
Clémentine
@Clémentine Arce i would suggest looking at Tempo Timesheet and Tempo Planner. The combination should meet all the requirements except the outlook integration. I think that is only available in cloud.
Hello Brant,
We already use Tempo Timesheets and Tempo Planner, but in DC they show some limitations for some of the requirements explained above, not just the outlook integration. Thus, we need to explore other options.
Thank your for your reply and suggestion, I am glad to see the tools we already use are not far-fetched compared to our needs!
Best regards,
Clémentine
