I have 10 stories, I need each story to have a sub-tasks. Is there a way to create sub-tasks in bulk?
(and also assign them a label and maybe a name pattern)
Automation samples
On transition
issue type = story
create subtask with summary of (Insert static text) for {{smart value}}.
On creation
issue type = story
refetch issue data
Create subtask with summary (insert static text) for {{smartvalue}}
Hi @[deleted] ,
Welcome to the community!
Have a look at Create on Transition for Jira
If you are well versed with automations you can refer: https://www.atlassian.com/agile/tutorials/how-to-auto-create-subtasks-with-jira-software-automation
Good Luck!
Kind Regards
Utkarsh
