Is there a way to Categorized a Next-Gen Project in JIRA?
Jaime Mabini
Currently, We have 20 or more existing projects in JIRA. Most of them are using Next-Gen Project set-up. We are trying to categorized all our projects in JIRA to easily locate projects and reduced confusions.
In Classic JIRA set-up, It is easy to categorized the projects. but, for Next-Gen it seems that the categorized option is not available.
Patrick Cartier [Candylio]
December 17, 2018
Hi @Jaime Mabini,
Unfortunately right now you cannot add next-gen projects to categories and I don't see any immediate plan for this.
You can, however, leave feedback for Atlassian and hopefully they will put it on the roadmap soon.
Jaime Mabini
Hello @Patrick Cartier [Candylio]
Thank you for your respond. And yes, I will do so.
