×Hello!
We are using the Jira Insight database to document and track all current versions of software our customers are using. We have created an object type "current customer versions" which stores all the current versions of software for our customers. These versions will link to the support ticket raised by the customer dependent on the software the issue is with.
For example:
Component: Example API
Version: 1.0.0
Dialog: A support ticket is raised and it is against the component Example API therefore the insight version (through automation) will automatically be assigned to that ticket so we know which version has the issue.
Because we don't want to clog up our object type with every version of every product the customer has used and we only want the latest version. Is there a way to archive objects so that previous tickets with issues for 1.0.0 will stay in that ticket rather than it automatically update to the latest version when we upgrade? Because we only want the latest version of the product for the customer, so we will always update the one object to the latest one rather than create multiple.
Insight has a status attribute so you can just use an "Archived" status to show which ones are still active or not.
If you want to avoid that they show up in the general object type overview you can always create a sub-type and move them there but in your IQL set the reference to also include Children.
I feel a status has more value than just a flag as it can be more encompassing.
Things like: Active, Archived, To Be Released, Impacted, ... these statuses can also be used in your Incident Management process when tickets are raised against them.
Hi Dirk,
Thanks for your reply. Your answer is very helpful.
I will give that a go.
George
Dirk, do you know if there is a way to move insight objects to a sub-type? Say if we wanted to have a sub-type where we could move all archived old versions. I can only see an option to clone. Do you know if this is possible?
Best,
George
Hi @George Bliss ,
in the past I had the same issue and I resolved with the following workaround.
All not active object will be not selectable by end user.
Hope this helps,
Fabio
Hi Fabio,
Your reply is much appreciated and very helpful.
George
