Is there a way to auto create a group based on a project's Roles
Kathleen Jacobs
There are a few thigns we want to use groups for. The groups are based off of the projects Roles.
Example: Project One
Have 4 roles and about 3 ppl in each one.
We want to use Level Security on another project and allow Project One it's own security. We can do this by adding a group called Project One to issue Security. BUT the people in that project change every so often.
Is there a way (Plugin, script, etc) to create and/or update a group so it matches everyone within a project? All roles?
Ramiro Pointis
June 12, 2013
John Chin
June 9, 2013
Hi there,
You can try to add Assign to role member function in JIRA workflow to update the user project roles.
Downloaded link - JIRA Misc Workflow Extensions plugin.
Maybe its help.
Regards, John Chin
Kathleen Jacobs
I need a group of everyone within a project. Not sure how this would help with that. maybe i'm not understanding.
