×In our kanban boards, we review issues based on the order that they are displayed. I'd like to be notified when someone is moving an item vertically or changing the order in which we will review them.
The order of issues is stored in an alphanumeric field named Rank, which behaves like a number.
You may save some JQL filters using Rank, and subscribe to them in order to be notified of certain rank changes.
However, this system relies on hardcoding known values into your filter, so it is not a handy method at all.
If you counted with a plugin like ScriptRunner, you would probably be able to set a better solution.
