×I am looking to build a dashboard for reporting off all the issues that my team manage. Noted current gadgets is pretty limited and based on one variable. Looking to cut and slice data based on multiple variable/ filters.
thank you
@Aron Gombas _Midori_ Thanks for pointing to eazyBI. eazyBI has quite many report options you can build for any small or bigger team. Here is our demo account with some reports and dashboard examples for inspiration. But there are many more to build.
Daina / support@eazybi.com
There are several BI apps available for Jira Cloud, but the most popular is probably EazyBI. It supports all the slicing and dicing features you're looking for.
(You can find alternative apps starting from the EazyBI listing.)
WYSIWYG where gadgets are concerned. If you feel you have explored all gadgets and still find them falling short then you might consider an addon app or simply using excel/sheets. However, if you could explain your exact goals maybe there is something within the existing offering that could work.
