Is there a way to bulk edit users in JIRA?
Susan Hazlett August 15, 2013
I am migrating from Bugzilla to JIRA and while the Bugzilla users come into the system under a group called "bugzilla-import-disabled-users" or "bugzilla-import-unused-users", they are coming in as "active". This is triggering an error for licensing, and with > 2000 disabled/unused users, I don't want to have to edit these all manually. Can anyone point me to how I can do this in bulk?
Thanks!
Henning Tietgens
August 15, 2013
You can use the Script Runner plugin and the following script:
import com.atlassian.crowd.embedded.api.CrowdService
import com.atlassian.crowd.embedded.api.User
import com.atlassian.crowd.embedded.api.UserWithAttributes
import com.atlassian.crowd.embedded.impl.ImmutableUser
import com.atlassian.jira.bc.user.UserService
import com.atlassian.jira.user.util.UserUtil
String result = ''
UserUtil userUtil = ComponentAccessor.userUtil
CrowdService crowdService = ComponentAccessor.crowdService
UserService userService = ComponentAccessor.getComponent(UserService.class)
User updateUser
UserWithAttributes user
UserService.UpdateUserValidationResult updateUserValidationResult
def groupNames = [
        'bugzilla-import-disabled-users',
        'bugzilla-import-unused-users'
userUtil.getAllUsersInGroupNamesUnsorted(groupNames).findAll{it.isActive()}.each {
    user = crowdService.getUserWithAttributes(it.getName())
    updateUser = ImmutableUser.newUser(user).active(false).toUser()
    updateUserValidationResult = userService.validateUpdateUser(updateUser)
    if (updateUserValidationResult.isValid()) {
        userService.updateUser(updateUserValidationResult)
        result += "Deactivated ${updateUser.name}\r\n"
    } else {
        result += "Update of ${user.name} failed: ${updateUserValidationResult.getErrorCollection().getErrors().entrySet().join(',')}\r\n"
return result
Please test in testsystem first!
Henning
Susan Hazlett August 16, 2013
Thanks, Henning. I ended up filing a support request with Atlassian, and it seems that this is not intended behavior of the importer. The script looks like it might be handy if there's not another solution. Thanks for posting it. If i need to, I'll test this out in my staging environment.
Bryan Karsh
June 22, 2014
For example,
This seems to work in script runner, but it doesn't store change.
String result = ''
User updateUser
def groupNames = [
        'deactivated-users',
    ApplicationUser appUser= userUtil.getUserByName(it.getName())
    updateUserValidationResult = userService.validateUpdateUser(appUser)
    } else {
return result
Henning Tietgens
June 22, 2014
Maybe a cache issue? Did you tried to refresh the JIRA cache (using the built-in script)?
Bryan Karsh
June 23, 2014
Hi Henning,
Still running into problems.
When I run the script, it says the users are deactivated. But even when I refresh the cache, and run it, same problem.
I ran the script and dumped out contents of updateUserValidationResult:
<com.atlassian.crowd.model.user.DelegatingUserWithAttributes@2f56ea4b user=testing-123:10400 user=testing-123:10400 attributes=com.atlassian.crowd.embedded.impl.ImmutableAttributes@3fb46d1f>
<com.atlassian.jira.bc.user.UserService$UpdateUserValidationResult@26537e15 user=testing-123(testing-123) errorCollection=Errors: {}
Error Messages: []>
<com.atlassian.crowd.model.user.DelegatingUserWithAttributes@82a778f5 user=jiratestuser:10400 user=jiratestuser:10400 attributes=com.atlassian.crowd.embedded.impl.ImmutableAttributes@7567e92b>
<com.atlassian.jira.bc.user.UserService$UpdateUserValidationResult@1c2c14f2 user=jiratestuser(jiratestuser) errorCollection=Errors: {}
Error Messages: []>
<com.atlassian.crowd.model.user.DelegatingUserWithAttributes@4bdf84b9 user=jira-test-user:10400 user=jira-test-user:10400 attributes=com.atlassian.crowd.embedded.impl.ImmutableAttributes@22dfddd4>
<com.atlassian.jira.bc.user.UserService$UpdateUserValidationResult@68e775cc user=jira-test-user(jira-test-user) errorCollection=Errors: {}
Error Messages: []>
<com.atlassian.crowd.model.user.DelegatingUserWithAttributes@473545d7 user=bryan-test:10400 user=bryan-test:10400 attributes=com.atlassian.crowd.embedded.impl.ImmutableAttributes@40111438>
<com.atlassian.jira.bc.user.UserService$UpdateUserValidationResult@3f24b87c user=bryan-test(bryan-test) errorCollection=Errors: {}
Error Messages: []>
<com.atlassian.crowd.model.user.DelegatingUserWithAttributes@b13858ff user=tempfix:10400 user=tempfix:10400 attributes=com.atlassian.crowd.embedded.impl.ImmutableAttributes@3f245740>
<com.atlassian.jira.bc.user.UserService$UpdateUserValidationResult@2e91ee6b user=tempfix(tempfix) errorCollection=Errors: {}
Error Messages: []>
Bryan Karsh
June 23, 2014
Hi Henning -- the link below has a version of your script that works in Jira 6.2.5.
Since you are the author, thanks! I appreciate all your examples in the forum.
import com.atlassian.jira.user.util.UserManager
UserManager userManager = ComponentAccessor.getUserManager()
User updateUser
errors = ''
userManager.getUsers().findAll{user -&gt; user.name == 'test-user'}.each { user -&gt;
    } else {
        errors += "Update of ${user.name} failed: ${updateUserValidationResult.getErrorCollection().getErrors().entrySet().join(',')}\n"
return errors
Henning Tietgens
June 23, 2014
Thanks for the kind words and a working version of the script. It's weird, the deprecated version of validateUpdateUser() using com.atlassian.crowd.embedded.api.User is working while the one using the ApplicationUser is not... Shortly we will switch to 6.2, maybe this is going to be fun... :-)
Bryan Karsh
June 23, 2014
Hi -- maybe I was having a cache issue originally -- because your script from Aug 13 works for me too without modification.
In any event, thanks again. :)
Mentorship4U July 11, 2020
I wrote a blog post on how to bulk edit Jira user e-mail accounts.
It's based on ScriptRunner and Groovy.
Cheers!
Marcus Silveira
June 23, 2014
I believe the best way to disable users would be to simply set their 'active' value to 0 in the database.
Just be sure to have a database backup before doing the changes.
Danilo Conrad
June 23, 2014
You may find the query to perform this change on the related post below:
https://answers.atlassian.com/questions/127643/how-to-deactivate-a-user-programmatically-java-rest-sql
