×When using swimlanes by assignee, sorting always defaults to alphabetically by user. Is there a way to change that to sorting by issue count, so workload highest-to-lowest (or vv) is clearer?
Hi @Kev Needham
Trust you are well.
If you are up to Marketplace Apps we suggest to try our Advanced Agile and Kanban Boards. You can create Swimlanes by Assignee. But you can also drag and drop them. We will remember the way you ordered it.
Just collapse all and re-order. Extend all and enjoy!
Many thanks & Kind regards,
Yuri.
Hi @Kev Needham welcome to the community! It looks like this is a feature request that has been submitted. You can vote for and watch it here: JRACLOUD-70540
Hope that helps.
