Is there a way to collect Insight Imports result with groovy?
Eugeny Chernyavsky
We have installed Insight version is 9.1.13, and we really would like to grab the results of Imports on daily basis.
The only info I've managed to find with Groovy is Configuration info about ImportSource and ImportSourceOT objects.
We really would like to have possibility to get some import run data like finished time, import results, errors if happened...
Eugeny Chernyavsky
We've configured database Insight import from AO_8542F1_IFJ_IMPORT_SRC and AO_8542F1_IFJ_PRG_RES and getting the reports for insight imports with the help of insight import. Looks like this is the way for now
PD Sheehan
April 14, 2023
The closest I can find is ProgressFacade.
But there is no method to list all the recent progress results.
It might be behind some hidden/internal API.
The only option I can think of is to query the db directly (AO_8542F1_IFJ_PRG_RES).
Eugeny Chernyavsky
Thank you for suggestion
I saw that before, but couldn't find they way to take Progress object except running import from groovy (start import method returning Progress object)
Maybe I missed something else...
