Is there a way to copy projects between two cloud sites?
Rita Zhou September 16, 2021
We have a requirement of copying project from one cloud site to another? Is there a way of doing that?
Danny
September 16, 2021
Hi @Rita Zhou
You could migrate a project following the steps in the migration documentation. The documentation has two paths;
  1. one for migrating to a new instance.
  2. one for migrating to an exisiting instance with data.
Though you would need to be or have access to the administrators of both instances.
Hope this helps.,
Danny
Actually, my requirment is:
1. migrate one project from server instance to the sandbox of cloud instance
2. do some cleanup and update the project in the sandbox
3. copy the project from sandbox to the cloud instance.
Neither sandbox or cloud instance is empty.
